Minor problem but bothering me.
Ccleaner font is not sharp enough as elsewhere.
Where is the problem?
You're right Andavari, everything is blurry.
And yes CCleaner 5.02.5101 and win 8.1 (64-bit) with all the latest updatest are correct. For the information I've tryed CC 64-bit and regular versions, both looks same.
Ok, I figured something out. It's realted with my laptops resolution i guess, in my case FHD 1920x1080. When I make changes CCleaner64.exe properties, fonts turning sharp and icons too but icons doesn't look smooth.
I don't know but perhaps an icon flushing tool will help remove the jaggedness if they're actually icons in the program, then again maybe not if they're bitmaps in the program.
