Flock Cleaning
I use Flock and I am very tired of having to go to it's temp folder to delete temporary files.
Could CCleaner please make something so we can clean Flock? :)
i believe flock is cleaned using the Google Chrome section
v2.33.1184 (24 Jun 2010)
- Added support for Flock 3.0.
- Improved database compacting to only run when needed.
- Improved Index.dat files cleaning for IE8 to include IECompatCache, IETldCache, PrivacIE folders.
- Improved accuracy of cleaning status messages.
- Improved localization and language support.
- Improved UI text formatting for Cleaner screen.
- Fixed Startup Tool double-clicking behavior on Win9x.
- Minor improvements to Registry Cleaner on Windows 7.
- Added Kurdish translation.
Also is your install of flock in the default install location (either %localappdata%\Flock\Application\flock.exe
or %ProgramFiles%\Flock\Application\flock.exe )
