I have noticed that CCleaner cleans the settings.sol from the following location by default:
%userprofile%\Application Data\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\settings.sol
I typically disable the update setting at the following location:
http://www.macromedia.com/support/document..._manager05.html
When you uncheck the update, it modifies the settings.sol file. Because CCleaner removes this file, the update setting is removed.
I like the FlashPlayer cleaning, but I don't think it should clean the settings.sol file by default. I know that I could make an exception for that file, but it's a pain to do it on every single computer I load CCleaner on.
If this could be addressed, I would greatly appreciate it.
Thanks
