Flash Cookies
I recently had an infection which I cleared up and one of the tools I used was SAS which detected a lot of cookies: Adobe Flash Tracking Cookies. How can I make ccleaner detect these? Adobe Flash does not show up in
applications.
Thank you.
applications.
Thank you.
Stop worrying about cookies as infections, they aint. It's under multimedia .
applications.
Thank you.
If you use a Gecko browser, SeaMonkey or Firefox, then the BetterPrivacy extension will control and delete Flash cookies. In K-Meleon the ClearFlash extension does much the same. The old Gecko browser Flock has the BetterPrivacy extension too. Read here about Flash cookies and here and here also.
What OS are you using
as stated above Flash cookies are cleaned via applications>multimedia>adobe flash player
so long as they are not on your cookies to save setting ccleaner (latest version) should clean them fine
Ok, thanks for the info
I have Win XP SP3
Adobe flash does not show up in ccleaner though. Applications/multimedia/adobe flash.
I use Opera 10.6 and win xp sp3
please try this
start regedit.exe (start menu run regedit.exe)
press F3 key
paste this string into the search box
{D27CDB6E-AE6D-11cf-96B8-444553540000}
and press find
let us know if it doesn't find the string (this is the thing that CCleaner is looking for for flash to appear in the list)
if it doesn't find it
press ctrl+f
and paste
Shockwave Flash Object
into the find box
press find
when it finds it press shift+tab, this should highlight an entry in the left hand pane
right click on the highlighted item in the left pane and choose "copy key name"
paste the copied item into a reply in this thread
press f3 to find the next occurance
copy and paste the key names as above until regedit can't find anymore items
please try this
press F3 key
and press find
press ctrl+f
and paste
into the find box
press find
It found three occurances-'value not set'.
Also note, I have two computers and flash doesn't show up on either one in ccleaner/
I don't think it shows up in CCleaner unless you also have the Adobe "Internet Explorer" plugin installed, which is different to the "Firefox/Safari/Opera" version.
http://www.adobe.com/shockwave/download/alternates/
I'm an Opera user as well, but I installed both versions.
EDIT: Just found this, which may be an alternative to installing the IE plug in.
http://forum.piriform.com/index.php?showtopic=28666&view=findpost&p=171803
DennisD,
Thanks, that probably is it. After cleaning up from my infection, it was recommended to get the latest flash, which I did through Opera. The other user on these computers uses IE, but it hasn't asked for the plugin yet so it has not been installed.
I was just alarmed at all the tracking flash cookies SAS found and want an easy way to keep them off even if they are probably benign.
Thanks.
