Firefox Not Showing Up on Clean
Hello! I have noticed lately that Firefox does not show up in the main (first) list for Windows as it has always done. It does show up in Applications list. However, there is no evidence that anything in it is being cleaned. The same amount of bytes show up in the Applications list as on the Windows list.
I checked out some of the previous posts on this issue, but they did not help. There was something about seeing whether or not Firefox was active in processes in the Task Manager. It is, but how do you manage to see what to do w/o it? I guess I could use IE.
Your time and effort are greatly appreciated!
;o) JG
. . . Firefox does not show up in the main (first) list for Windows as it has always done.
Should appear only on the Applications list cos it's not part of Windows.
. . . there is no evidence that anything in it is being cleaned. . . seeing whether or not Firefox was active in processes in the Task Manager. It is . .
You shouldn't see Firefox active in Task Mgr cos internet browsers are supposed to be closed before running CC.
The applications and Windows tabs are cleaned simultaneously
