Filter function doesn't work for double-byte strings
I'm a Chinese user, and I try to enter some Chinese filenames in the "Find" textbox.
Recuva can't filter these filenames, but these files are listed in the searching result.
Please try to fix it. :rolleyes:
Hi, can you answer a couple of questions for me:
1. Did you press Enter after typing?
2. Which Chinese character set are you using?
Thanks
MrRon
