I have had this problem for a couple of months now and no idea what it is, i searched the forums but havent found any solution:
The connection was reset
The connection to the server was reset while the page was loading.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
is this working for you? I have tried it on different browsers but still no luck. This is my favourite place to look for updates for software so any help is much appreciated ![:)]()
I dont know, I never visit that website.
Most of my downloads are from SourceForge.net
I don't use firefox but found your error messages on here, so others must have the same problem sometimes! Do you have the latest version of FF?
http://wiki.mozilla.org/Firefox:1.5_Networ...es#netInterrupt
Also this site may be of interest,
http://kb.mozillazine.org/Error_loading_some_websites
yes im using latest version of firefox, also im getting the same problem when i use other browsers. It only happens when i try to download a file from the site.
Hi Misao. That isn't a browser error. I was having the same problem for 3 weeks. It was driving me crazy!
I tried everything, 3 different browsers, reconfiguring my network, computer repairs, etc....
The problem ended up being with my ISP. My ISP insisted that nothing was wrong, but when a tech came out they found many problems with the wires.
Have you had your machine checked for malware? Have you posted a HJT log here? If you have had your machine checked was any malware removed? Sometimes after removing malware this problem can occur and you may need to do a winsock fix.
Finally someone who has had the same problem
no never used HJT definately will try it and post a log asap.
Perfect! After Andy is finished helping you I will help you finish, okay? ![:)]()
ok thanks, i got my log posted ![:)]()
Spot-on the log shows a broken LSP!
Good! That's what I was hoping would show up.
Andy will probably go ahead and fix it then.
