Deleted a Microsoft Outlook ".pst" file and ran CC. Is there any way to restore the file?
Help please; years of serious emails and contact info.
Thank you.
Thank you.
Ok, try not to move around your browser too much to to avoid getting windows to overwrite the file.
Download Recuva form here or download the portable version so you dont have to install.
Run it and search the location from where you deleted the file (look in the recicle bin if you deleted it from there)
Hope it works.
It worked. Thank you VERY Much!!
Happy to help.
Welcome to the forum, by the way.
