File recovered in multiple parts
Hi all,
first of all I would like to thank you for this software, it's really helpful! Thanks!
I have a stupid question regarding a recovery session that I performed successfully. I can see all files, some of them are readable, others are not and some of them are splitted in several parts (e.g: fileBlabla.eml, fileBlabla_01.eml, fileBlabla_02.eml).
If I try to read a part of this file I cannot see anything but I'm wondering if it's possible to re-join/merge them in order to get a readable file...any ideas?
Thanks all.
These are recoveries of separate files which have the same name, either in different directories or the same file created and deleted many times (isn't .eml an email file?). Recover adds the numbered suffix to avoid name conflicts. You could try to merge them but I don't think that there's any chance of success.
