Hello .The 5.04.5151 version has an annoying bug. The bug appears when the user starts a Reigstry Cleaner scan. When the scan finishes it tells you that there were detected many issues. The bug is that the issues are fake and there are more than 5000 detected (it detected 9512 issues for me
). When I checked the registry those issues didn't even exist. The Registry Cleaner IS showing FAKE issues. Anyway the bug seems harmless cause it doesn't delete those registry keys, it only deletes the real ones
. Hope you guys fix this cause this is really annoying
. Screenshot:
How are they "fake"? if you mean not invalid, then you need to read my signature (which contains good solid advice for the registry section)
Fake = False Positive
That's my thought, however you never can guess
