Hi all,
Defraggler v2.10.424 (64-bit) is failing with the message "Analysis Failed" on a Fantom 3T (3,000,581,881,856 byte) "GreenDrive3" USB drive.
The error comes back right away. I have several other USB drives connected to my computer (all smaller, about 1.5 TB), and Defraggler works great on each of them. I only have a problem on this one (large) drive.
I've attached a log file of the attempt in debug mode.
Great product by the way. Absolutely love it, and great new features!
Defraggler64.exe.2_10_4242012-07-28_00-37.txt
This is a known bug/issue as you may find out when searching the forum.
As a temporary fix, you may be able to backup all files from your 3 TB drive, then repartition it as two 1.5 TB partitions. Hope this is fixed soon!
Thanks for the replies. Did a quick search for this but nothing came up right away. --Think I'll go to the suggestions forum and suggest a "known issues" page, unless someone already has that out there.
The native windows defragmenter will handle the 3T drive, so I'll probably just use that for now. But it's definitely not as good. :-)
