Extension Bugs in V3.04.1389
Just updated to V3.04.1389 and now when I run the registry cleaner it keeps finding .STEP, .igs etc all CAD dwg file exensions I use with CAD programs I have and use. Even if I delete them they're just going to return when I use those programs. What was done with this update that all of a sudden it's finding these extensions? Is there some way to tell CC to ignore these extensions in it's cleaning process? I look for anyone's comments.
Yes. Read here. :)
Yes. Read here. :)
Yeah, but the "improved cleaning" is in my opinion aggressive and is finding an awful hellish amount of file extensions/filetypes, I won't clean them since allot of the list was for software that's installed.
I don't intend to clean them, either. I'll just add them to the Exclude List, which is what I suggested to the OP. :)
I agree, its picking up about 25 entries here that even Regseeker leaves alone!
