In section Option/Custom i can add/remove file & directory, but when I install a new version, I lose my settings and so I have to re-add every file/folder.
Instead, if you could import the old settings I would make it automatically
Ok, usually I unistall the old version and after I install the new version...
Thanks
If installing over an old version doesnt remove the settings then that is sure that some file(s) are preserved. Ask CCleaner support or ask in forums about the file.
All files are overwritten, it just doesn't change the registry settings for it.
