eMule (Search History)
[eMule (Search History)] ID=2080 LangSecRef=3022 Detect=HKCU\Software\eMule Default=True FileKey1=%ProgramFiles%\eMule\config|AC_SearchStrings.dat
When you install eMule you have 3 choices
Currently, CCleaner eMule cleaning only works if you use the 2nd option (which is not the default one, at least on Vista/7).
If you keep the default option (the 1st one), you should search for eMule config inside the user folder (example: %LocalAppData%\eMule\config for Windows 7).
You should also provide support for the 3rd option ("All Users" folder?).
eMule (File Hashes)
[eMule (File Hashes)] ID=2081 LangSecRef=3022 Detect=HKCU\Software\eMule Default=False FileKey1=%ProgramFiles%\eMule\config|known.met FileKey2=%ProgramFiles%\eMule\config|known2.met
Same thing.
Also, on my system I have "known.met", but I don't have "known2.met" while I have a "known2_64.met" file.
eMule 0.50a
