For the latest version (4.08.4428 64-bit Windows 8) and the previous two versions, whenever I'm cleaning my hard drive, it says that it's emptying my Recycle Bin (even though it's already empty). It's always 42,931 KB, 28 files. No matter what or when I'm cleaning, this always appears. I've uninstalled and re-installed CCleaner, but it always shows up. I've tried different wiping methods (3, 7, 35) to no avail. It doesn't on my other computers though. What could I do to get rid of this entry? Thanks. --FoS
Perhaps your recycle bin is not working correctly, if it is deleted Windows will automatically build a new one when you re-boot.
See here
http://www.thewindowsclub.com/recycle-bin-is-corrupted-windows
I am having the same problem with Windows 8.1. I will try to delete the recycle bin as per the post above and let you know what happens.
I am having this issue on 2 pc's, both running Windows 8.1. I tried the "build a new recycle bin method" on one and it seemed to work. However, now my other pc is having the same problem - beginning to believe it's a CCleaner "bug".
can't replicate the OP problem here.
CC v4.08.4428, Win8.1, 64bit
Recycle Bin already empty, run CC which also empties Recycle Bin.
All good.
Delete something, Recycle Bin shows it, run CC, Recycle Bin empty.
See here
Thank you for the suggestion. It worked! Happy New Year!!!
Glad to hear it worked for you Field of Stones.
Happy New Year to you too
