Ei.cft Removal Utility
Link: http://icedtech.blogspot.com/2010/01/eicfg...al-utility.html
Nice find. I was trying to find what use it would be till you mentioned the lost disc scenario.
AJ
Thanks! Lol, I misspelled the title. It's actually Ei.cfg Removal Utility. :lol:
When I follow the Giveaways link on the right of the page and go to look at Wondershare spyware removal and follow it's link, Malwarebytes blocks the link as malicious.
False Positive. I didn't get infected with anything when I visited the giveaway link, and I also check all the links that I post to see if they are bad ones. Turns out other sites have posted about this offer as well, so it must be safe.
Thanks, Icedrake. Got it. W7 is probably years down the road for me, but will add it to the "Downloadaholic" folder. :P
