edge browser not close these days
1 hour ago, user20182019 said:
		All right, i find where that is , i have that on, have to think.
.. and then after that, closed browser, test with cc-cleaner .. "edge needs to close..", not sure what to do, because i feel most of my system
works as needs using this fast start? what is recom setting?
Is this same if uses SHIFT same time when select close computer from left down corner?
I noticed task manager, computer was on 26 hours in row(which is not true, means not fully closed then), but after closing with SHIFT pressed , then opening again
from power button, task manager only 1 minute on in row?
I have read about this fast or slow start before too but if this type helps to edge problems too, probably worth use?
		Is this same if uses SHIFT same time when select close computer from left down corner?...
Hi user20182019:
Yes, I believe that is correct. According to the dispromo article Shutting Down Doesn’t Fully Shut Down Windows 10 (But Restarting Does), if Fast Startup is ENABLED then you can perform a full shut of the Windows kernel down "by pressing and holding the Shift key on your keyboard while you click the “Shut Down” option in Windows. This works whether you’re clicking the option in the Start menu, on the sign-in screen, or on the screen that appears after you press Ctrl+Alt+Delete." However, if Fast Startup is DISABLED then you do not need to hold the Shift key to perform a full shutdown.
		... I have read about this fast or slow start before too but if this type helps to edge problems too, probably worth use?
Yes, I think it's worth leaving Fast Startup disabled, even if disabling that Windows power option and then powering your computer off (Start button | Power | Shut Down) and back on a few times does not fix your MS Edge problems. See the section titled "Why disable fast startup?" in the WindowsCentral article How to Disable Windows 10 Fast Startup (and Why You'd Want To) for more reasons why you might want to disable Fast Startup. I know of many third-party programs, especially programs that load early in the boot process like Norton, McAfee, and other antivirus software, that can behave erratically and display all sorts of odd behaviour unless Fast Startup is disabled.
After testing for a week or so, if disabling Fast Startup dramatically increases your shutdown and startup times (which I doubt it will) but hasn't fixed any odd glitches you've noticed on your computer then you can turn Fast Startup back on again.
________________________________________
Keep in mind that you don't need to use CCleaner to clean your MS Edge browser data. I have my MS Edge browser configured to clear most of my browser data on exit (Privacy, Search and Services | Clear Browsing Data | Choose What to Clear Every Time You Close The Browser) so there isn't much MS Edge browser data that needs to be cleaned when I run my weekly Custom Clean with CCleaner.
MSEdgev120_0_2210_121SettingsClearBrowerDataonClose08Jan2023.png.dbd7632a5ce7ad61f37f8e299e012f10.png
<span style="font-size:11px;">Dell Inspiron 15 5584 * 64-bit Win 10 Pro v22H2 build 19045.3803 * Firefox v121.0.0 * Microsoft Defender v4.18.23110.3-1.1.23110.2 * Malwarebytes Premium v4.6.6.294-1.0.2201 * Macrium Reflect Free v8.0.7783 * CCleaner Free Portable v6.19.10858</span>
		Hi user20182019:
		Yes, I believe that is correct. According to the dispromo article <em><a href="https://www.disprimo.be/shutting-down-doesnt-fully-shut-down-windows-10-restarting-does" rel="external nofollow">Shutting Down Doesn’t Fully Shut Down Windows 10 (But Restarting Does)</a></em>, <strong>if Fast Startup is ENABLED</strong> then you can perform a full shut of the Windows kernel  down "<em>by pressing and holding the <strong>Shift key</strong> on your keyboard while you click the “Shut Down” option in Windows. This works whether you’re clicking the option in the Start menu, on the sign-in screen, or on the screen that appears after you press Ctrl+Alt+Delete</em>."  However, <strong>if Fast Startup is DISABLED</strong> then you do not need to hold the Shift key to perform a full shutdown.
		Yes, I think it's worth leaving Fast Startup disabled, even if disabling that Windows power option and then powering your computer off (Start button | Power | Shut Down) and back on a few times does not fix your MS Edge problems.  See the section titled "<em>Why disable fast startup?</em>" in the WindowsCentral article <em><a href="https://www.windowscentral.com/how-disable-windows-10-fast-startup" rel="external nofollow">How to Disable Windows 10 Fast Startup (and Why You'd Want To)</a></em> for more reasons why you might want to disable Fast Startup.  I know of many third-party programs, especially programs that load early in the boot process like Norton, McAfee, and other antivirus software, that can behave erratically and display all sorts of odd behaviour unless Fast Startup is disabled.
		<a data-fileid="18276" href="<fileStore.core_Attachment>/monthly_2024_01/MSEdgev120_0_2210_121SettingsClearBrowerDataonClose08Jan2023.png.dbd7632a5ce7ad61f37f8e299e012f10.png" title="Enlarge image" data-fileext="png" rel=""><img alt="MSEdgev120_0_2210_121SettingsClearBrowerDataonClose08Jan2023.png.dbd7632a5ce7ad61f37f8e299e012f10.png" class="ipsImage ipsImage_thumbnailed" data-fileid="18276" data-ratio="68.59" width="608" src="<fileStore.core_Attachment>/monthly_2024_01/MSEdgev120_0_2210_121SettingsClearBrowerDataonClose08Jan2023.png.dbd7632a5ce7ad61f37f8e299e012f10.png" /></a>
I know that cc-cleaner not needed , but that was problem before too ,because last year at least, many months or weeks , that setting also was not working.
Now i need to follow that too, if i am logged out from site or already in when open browser again. So there are two things i follow,
background on/off, cookies etc. on/off like in settings.
Seems this "long" start is quite fast too, i keep that off then, maybe uses less power too when closed.
