Oh, apparently my license has expired. I didn't know I bought a product that had an expiry date!
@WalterSwanIf you bought in 2017 then your product doesn't expire, but the services did back in 2018 (customer support; new features such as Health Check, Driver Updater, etc).
I just purchased the full CCleaner program today after seeing the Driver Update option. The minute I purchased the full program and initiated the driver update, it bricked my computer. An absolute waste. This program should not even be available to the public with how astronomically disastrous the consequences are. I'm sitting here, hours in, attempting to save my PC. I have never been more disappointed in a program.
Hi @spcesq Thanks for the suggestion as I can definitely understand the value in having a progress bar for the driver update operation and I'll send this directly over to our product team for further review and consideration.
If you ever have any other suggestions, please let us know; we greatly appreciate all feedback as this is one of the best ways for us to improve our products and services.
Hi everyone! Thank you for the suggestions and feedback so far. Your comments really help us in our quest to make ours the best Driver Updater out there!
It's been almost a year since we released Driver Updater. Here's a quick recap of improvements we've made since releasing the feature:
Improving the reliability of driver updating
We added an automatic scan, which runs once per week
We added better communication between CCleaner and Windows to determine when to update a driver
We refined our driver-matching technology to consider more factors about the driver device origin when deciding where to source updates from
We fixed issues where it took multiple attempts to update a long list of drivers
Getting help if something goes wrong
We created a guided revert driver flow that helps you to identify the most likely updates related to an issue you are having, so you can easily revert them
We made the button for reverting drivers more obvious
We created custom error handling/messages for different types of connectivity errors
Quality of Life Improvements
We fixed various bugs to make the experience of using Driver Updater smoother
We added a counter in CCleaner Professional to let you know when you have drivers to update
We added the date of the latest driver to make it easier to confirm that it was the latest one available
Altogether, these improvements have significantly reduced the likelihood of driver update failure and the need for you to revert driver updates. We also see this drop reflected in your feature experience ratings: our average customer rating for the Driver Updater feature increased to 3.8 out of 5 (up from 3.4 - a 12% increase!)
But we won't stop there! Here is what we'll focus on next:
Further increasing reliability of driver updates
We want to address the situations where driver updating ends badly. This is very technically challenging, so will take some time to get right. Nevertheless, we are committed to improving it.
We have a dedicated engineering team who are focused on continuous improvement of our driver update technology. They continuously look at the driver with the highest volume-to-failure rate ratio and iteratively work through these from top to bottom (as you can imagine, this is a huge list so there needs to be a sensible method of prioritisation to make improvements that impact the greatest number of users)
We want to find ways to make this a less manual process so we can increase the speed of fine-tuning the driver updates when they're not a good match
An Ignore function
We currently allow you to skip an update for a device
The next step is to allow you to completely ignore all driver updates for a specific device
Clearer progress indication
Currently the progress bar only shows the progress of updates in the list, but not progress for an individual driver
When a driver is updated, we go through multiple steps:
Download securely
Check that the downloaded driver file is exactly what we expect it to be (a security feature that protects against hacking)
Check how compatible this update is with the system
Talk to Windows to apply the driver update in the correct way
Confirm to you that the update was successful
This takes a long time, so we want the progress bar to help you to understand how far through this process you are (especially as the update file download can potentially take many minutes).
Do you have any suggestions for how we can improve Driver Updater? Please comment here in this thread! :)
..... how can delete the "updates" from the driver Update menu?
If you click on the 'Details' button next to each driver then you get an option to 'Pause Updates' which will stop it trying to update drivers for that device.
There is also a 'Skip this version' for that update, so it won't be shown again until there is an even newer version.
Which you use depends on if you want to block all future driver updates for a device or just the one.
eg.
TBH I never use Driver Updater and just ignore it altogether.
Updated to v6.26 today and basically now seeing the same issue when using the Driver Updater as some time ago (now seems largely fixed) happened when using Software Updater.
Today, after the update, showed I needed to update 3 sets of drivers (5 drivers in total). Selected first set, the updater then just sits there forever saying "Preparing to update selected drivers". After seeing nothing happen for an hour, I finally tried to cancel - this does not work, so killed the process and also rebooted laptop just in case. The strange thing is when you restart CC and run a scan, the two drivers which the previous update had just hung are no longer shown in the new scan (it now shows just 3 drivers outstanding), but if you check when these drivers were supposedly updated, it was before today ? I tried the same process, this time selecting all remaining drivers (3 in two groups), and the exact same thing happened. This time did not reboot, just closed/reopened CC and voila, the drivers all show no updates needed, but again, no updated drivers for today.
I am sure this will be fixed in a future (hopefully next) release, but as a paid up user I cannot be doing with such poor application updating.
Please advise how to revert to previous version of CC - which the driver updating worked perfectly on, and please update here when you have fixed this new bug.
Since I have set my Windows 11 PC to Automatic Driver Updates, unless that functionality is not working properly, why would C-Cleaner ever find out of date drivers on my PC?
The driver updater is not actually correct in anything that it âchecksâ because I got a driver version of 10.73.815.2024 which was installed on 25.12.2024 and is apparently from 15.08.2024 according to CCleaner, yet the manufacturer said it was released 08.01.2025 and installed 20.03.2025
So where is the information coming from? And why is it wildly incorrect?
Last week CCleaner gave me a bad Reaktek driver. I tried everything except System Restore because I did and installed a lot of new thing the night before. Device Manager Uninstalling from there did not work. I would think CCleaner would have a back up for driver like they do when cleaning up the registry and the file ccReg is placed in itâs folder do the same thing with the drivers. Realtek, itâs site was mostly Chinese, Device Manager didnât work. I couldnât use my computer speakers for four hours until finally my friend an IT technician stopped by and did something so technical I couldnât follow. Otherwise, the next day it would have cost me $150 down the street!
PS. You might notice there that I donât update my drivers just because some âupdaterâ says there is a new version.
If a driver is working then there is no need to update it.
Why try to fix what isnât broken?
Especially if doing that update may cause problems with the device that the driver is for.
Just because a driver is a ânewerâ version it doesnât mean that it is compatible with your hardware, itâs probably a new version for new hardware that you donât have.
Audio drivers seem to be the worst for that with new versions being for brand new hardware and not being compatible with even last years hardware.
Why bother adding this to CCleaner? If it will more likely break things, I wouldnât say thatâs very helpful. Why include it on CCleaner if it does more harm than good?
Iâm another one that has had problems with the driver updater. No one from Cclean seems to want to help so I thought Iâd try here! I have 2 plug and play screens that were working perfectly until I used the free trial upgrade and did the drivers as well.
Iâve now got 2 screens displaying the same thing and the resolution is incorrect. The money after the free trial has gone from my account just to make it worse.
Itâs an old pc running windows 10 but I need the 2 screens for my college work. Iâve tried everything in the sticky plus the basics of unplugging them etc. Customer service asked for more info (which Iâve given) but it says the email is not monitored. Iâve tried again with a new submission last week but no one has responded.
Please help, as the stretched screen and switching tabs is driving me insane.
