AMD Chipset Software 3.10.22.706 and Marvell Aqtion 3.0.18.0 installed, Driver Updater suggest to update those to older drivers that it for some reason thinks are newer.
AMD PCI 1.1.0.6 is also wrong, the newest version is 1.0.0.83.
Can you please contact our support team so that we can investigate this further? You can do so via the Contact Us form located here: https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 or by emailing support@ccleaner.com directly.
Please provide the support team with the following log files:
C:\Program Files\CCleaner\Data\DUState.dat
C:\Program Files\CCleaner\LOG\DriverUpdaterLib.log
C:\Windows\INF\setupapi.dev.log
These can be found by opening Windows Explorer and navigating to the folders indicated then send us a copy of the files listed above.
Additionally, can you please send us a report from the System Information utility in Windows?
You can save the System Information report using the following steps:
Open the "Run" dialog in Windows (On the keyboard, hold the "Windows" and "R" keys simultaneously)
Type: msinfo32.exe > click OK
Click File > Save...
Please also provide any other information that you have that may be helpful, we'll be happy to take it into consideration!
