Drive Wiper - not wiping external drive
I've scanned through existing posts, didn't see anyone with my problem so I'd thought to ask.
I have an eSata/USB drive dock that I am using to erase a stack of 74-300GB SATA drives, but am having problems with Drive Wiper not doing it's job.
I select
"Entire Drive (All data will be erased)
Simple Overwrite (1 pass) or DOD 3pass
Select the drive (E:) typically
Click Wipe
Type ERASE and select OK
After about 30-90minutes it finishes.... but the drive's data is untouched.
Am I doing something wrong?
On the Drive Wiper screen are you sure you changed the "Wipe" option from "Free Space Only" to "Entire Drive"?
Yes
Notice I said I was promtped to type "ERASE"?
This will only occur if you choose entire drive.
I figured out a workaround...I just do a quick format of the drive, then select Wipe Free space (3pass DOD)....it wipes the whole drive, not just the free space.
Good enough for me.
I seem to be experiencing this problem also.
I have a notebook hard drive attached to a USB SATA adapter.
CCleaner version: v3.07.1457
OS: MS Windows XP Home SP3
I chose the "Entire Drive (All data will be erased)" option with 1 pass. It doesn't seem to actually format the partition I have selected. After Drive Wiper is finished, I can still see all my files in Windows Explorer.
Guys, I experienced the same issue recently, and the devs are aware of that, and will I'm sure be looking at it.
From what you say, you're not doing anything wrong.
