Drive wipe
im am having an issue with drive wipe i had about 30gb give or take a few gig.
it show i had only 600mb of space ran it again nothing restarted my pc and got back 10gb of space does anyone know where the file is so i can delete it
Look in the root directory for example if you ran it on drive C: look in drive C: but don't go into any sub-folders, there should be files or folders that have allot of Z's in the name, those would be the file created during the wipe and should be large in size.
thanks for the help but still can not find it
Try disabling Hidden Files and Folders in Windows. I can't remember if it hides those files, or if they're just plainly visible.
Failing that use windirstat to find the culprit folder.
https://windirstat.net/
