Drive Map Question
I was thinking about posting a suggestion but thought it might be better to ask a question here first; it's about the drive map.
Defraggler is by far the best defragger I've found for Vista, but even after following all the guidelines - cleaning first, deleting hiberfile.sys, deleting unnecessary restore points, defragging in safe mode, etc. - there are still blocks that are left red. I'm assuming it's because they're inaccessible for some reason. If I highlight a red block and try to defrag the individual files, some of them defrag but othes won't. This doesn't really concern me, but I was wondering if there's an easy way to tell if they're simply unmovable or still fragmented? Other defraggers usually distinguish between the two with different colors. Does Defraggler have something like this that I'm overlooking?
Thanks. :D
