when i defrag system restore files they get somehow corrupted
The last time i used defraggler i defragged the system restore point files and later i had to do a system restore and every restore points failed
system = windows xp pro
need some expert input
i need some tools to prove if the files have been changed or corrupted by defraggler
i need tools the will tell me if they have been modified in any way
thank you
You don't say which Operating System you're using, but if it's XP I've had a few System Restore failures caused by I really don't know what.
Partly as a result of that, I never defrag System Volume Information (System Restore) files, because I believe you're adding the possibility of losing the integrity of those files by messing with them.
I don't know of any way to test their integrity, so I would recommend excluding them from any defrag, and occasionally have a clean out of them with Disk Cleanup.
My humble opinion of course.
how can i trust defraggler
i need to know if defraggler is corrupting other files too
need tools to verify files integrity
thanks
