I have just downloaded/installed and run "Speccy", as it seems to be a tidier, simpler application then the one I have used (SiSoft Sandra).
This application (Speccy) correctly identifies my Motherboard and CPU, but it does not show the Temps/Fanspeeds etc. that I was expecting.
Sandra provides both CPU and Motherboard Temps and CPU and Chassis Fanspeeds - the basics for an environment monitor as well as a load of other stuff I don't need.
Speccy provides a really nice clean interface that can be cleaned of clutter/expanded as you see fit. It has found a temp sensor that sandra does not display for one of my disk drives. How do I configure Speccy to find the CPU and Motherboard Temps and CPU and Chassis Fanspeeds?
Processor
Model : AMD Athlon XP 2200+
Speed : 1.8GHz
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Integrated Data Cache : 64kB, Synchronous, Write-Back, 2-way, 64 byte line size
L2 On-board Cache : 256kB, ECC, Synchronous, Write-Back, 16-way, 64 byte line size
System
Mainboard : MSI MS-6712
BIOS : American Megatrends Inc. Version 07.00T (04/02/01)
Multi-Processor Advanced PIC (APIC) : Yes
Sample from Sandra:
Date & Time : 03 March 2010 23:25:40
Board Temperature : 30.0?C (Min 30.0?C; Avg 30.0?C; Max 30.0?C)
CPU Temperature : 51.5?C (Min 51.5?C; Avg 51.5?C; Max 51.5?C)
System Fan : 2637rpm (Min 2637rpm; Avg 2637rpm; Max 2637rpm)
CPU Fan : 4787rpm (Min 4787rpm; Avg 4787rpm; Max 4787rpm)
CPU DC Line : 1.67V (Min 1.67V; Avg 1.67V; Max 1.67V)
+3.3V DC Line : 3.24V (Min 3.24V; Avg 3.24V; Max 3.24V)
+5V DC Line : 4.87V (Min 4.87V; Avg 4.87V; Max 4.87V)
+12V DC Line : 12.06V (Min 12.06V; Avg 12.06V; Max 12.06V)
CPU Core Power : 63W (Min 63W; Avg 63W; Max 63W)
CPU Cooling System Thermal Resistance : 0.34?C/W (Min 0.34?C/W; Avg 0.34?C/W; Max 0.34?C/W)
From Speccy:
Motherboard
Manufacturer MSI
Model MS-6712
Version 1.0
Chipset vendor VIA
Chipset model KT400 (VT8377)
Chipset revision 00
Southbridge vendor VIA
Southbridge model VT8235
Southbridge revision 00
CPU
AMD Athlon XP
Cores 1
Threads 1
Name AMD Athlon XP
Code Name Thoroughbred
Package Socket A (462)
Technology 0.13um
Specification AMD Athlon XP 2200+
Family 6
Extended family 7
Model 8
Extended model 8
Stepping 0
Revision A0
Instructions MMX (+), 3DNow! (+), SSE
Bus speed 133.3 MHz
Rated Bus speed 266.7 MHz
Stock bus speed 133 MHz
