In another thread a poster wrote that his HOSTS file was blocking a site I recommended called Oldapps.com. It made me recall my experience with the HPHOSTS file, (which I assumed was the one he was using).
I used to merge it with the MVPS HOSTS file and found that:
1) the two of them together made for too large a HOSTS file and slowed my browsing to a crawl
2) HPHOSTS consistently blocked some sites which are pretty safe. If you browse their list, you'll be amazed at some of the sites it blocks. It's a good and worthy HOSTS file, and it's better to be safe than sorry, but I think it overdoes the security just a bit.
Personaly I"m currently just using the MVPS HOSTS file with HostsXpert from Funkytoad.com as my manager of choice.
As a poster commented in another thread, Oldapps.com has an OK Siteadvisor rating. In addition, I've checked and it also has a "Trustworthy" green rating from Web of Trust.
I think that if a file download site hosts any file which has ever had a reported problem, HPHOSTS blocks the site.
Zone Alarm Pro's spyware function continuously would block Tinyurl.com until I added it as an exception!
Update:
I just downloaded latest version of HPHOSTS file. It's over 3 mb! That's almost 6x the size of the MVPS HOSTS file! That's some serious domain scanning going on when visiting each website! I opened the file with Notepad, and sure enough it blocks Oldapps.com. It even blocks Freedownloadmanager.org, which also has a "trustworthy" WOT rating.
However, I must add that the HPHosts site is very impressive in that there's some nice utilities for downloading, some good links provided, and the HOSTS files has updates and signatures provided. In addition, when searching for a domain such as Oldapps.com to see why it's blocked, much information is provided with links to many reports:
http://hosts-file.net/default.asp?s=oldapps.com
HPHOSTS gives Oldapps.com their EXP rating which means:
As I stated before, I think that if a site has ever hosted a file for download that was reported to be malware or adware, HPHOSTS blocks it. One look at Siteadvisor's rating here http://www.siteadvisor.com/sites/oldapps.com and you can see that there were files hosted that triggered the HPHOSTS alarm.
HPHOSTS even links to the Google report:
http://www.google.com/safebrowsing/diagnos...s.com&hl=en
Does anyone know how often HPHOSTS reviews this list and removes sites that are clean? Their HOSTS file seems quite large, so it must not be done that often.
