Does CCleaner wipe out information necessary to perform a system restore?
I recently installed and ran CCleaner and am more than pleased with its results. However, I don't know if this directly correlates with CCleaner, but my laptop now will connect to my wireless router but not access the internet. I tried to do a system restore, and it was unable to complete. Did CCleaner remove information necessary to perform the system restore?
A friend of mine has run CCleaner on a laptop with identical results. No internet and unable to perform a system restore.
Anyone figure this out?
Same here, not tried it on main computer yet though! - As a newbie, can I safely run the scan on the main one without un-ticking any boxes please?
Don't want to lose anything as haven't backed-up all the important stuff yet. -_- (Freecom Classic 80GB).
I use a latptop and wireless sometimes. I have never had a problem with anything.
I've used CCleaner regularly for a couple of years on both laptops and desktops using wireless without any problems.
Are you using the Microsoft wireless client or another? Does your wireless router have an event log? If so, does it show an error when you try to connect to the internet?
When you attempt a System Restore, do you get an error message? When you attempt a System Restore, are you closing any applications that might be protecting/locking any files, e.g., Norton Internet Security will prevent a System Restore if "Turn on protection for my Symantec product" is enabled.
