Does Ccleaner treat Chromodo as if it was Chrome?
Just updated to win 10 and, yes, I had to redownload Ccleaner.
Now the format has changed, whereas before it used to have a tick box for 'Internet History', it has one for each browser I have... except Chromodo which I prefer because it's all the fun of Chrome with non of the resource hogging.
So, does CCleaner treat Chromodo as Chrome or is there a way of getting Chromodo recognised by Ccleaner?
Maybe have a look in here:
http://forum.piriform.com/index.php?showtopic=22436
Edit:
Also look here:
http://www.piriform.com/docs/ccleaner/advanced-usage/ccleaner-ini-files/how-to-clean-user-data-from-non-standard-mozilla-browsers
Although the above link shows Firefox (couldn't find the Chrome one for some reason) here's how to get a Chromium/Chrome browser to work with it.
Example, instead of Firefox it could be something like this for your Chromium/Chrome browser, you'll of course have to find the full path to where your profile folder is located:
CustomLocation1=CHROME|C:\Path To Chromodo\Chromodo\Profile
