Does ccleaner only clean C: drive?
for example i have two drive on my PC (C: and D:), when i perform ccleaner, does it clean all of my drives or not?
Regards
Regards
Ccleaner only cleans files from your system drive (the one your operating system is installed on)
However you can ask it to clean custom files and folders
http://www.piriform.com/docs/ccleaner/using-ccleaner/including-files-and-folders-for-cleaning
thanks a lot. i want to add i installed my softwares on both of my PC drives. some of them on c: and others on d:, with this information do you will answer the same?
if yes, is there any free software for cleaning all of hard disk (all of drives)?
You can make winapp2.ini entries or recreate a new winapp1.ini either one will allow you to clean other drives
a question: is this dangerous to add another drive such as F: that some one also installed some programs on it to cleaner?
Like add f:\ by itself
yes unless you want the entire drive to be erased.
Please read the links I provided
