Hi, I gess it's all in the subject: does CCleaner delete cookies? When beginning to run it just now, I thought it said something about 'cleaning tracking cookies'. I want cookies. They store data that makes it easier for me to surf. If I wanted to clean cookies I'd have Windows do it - but I don't.
So is that that is meant by 'cleaning tracking cookies'? If so, crapcleaner is not for me.
ccleaner typically removes cookies but you can set it to save the cookies that you want to save.
browsers also can be set to remove cookies and to save the cookies that you want to save.
also, these days, browsers have "tracking protection" that blocks cookies. not all cookies, but some cookies.
google is working on ending the use of all cookies but we will have to see how that works out.
cookies are no big thing. as i said, you can use settings to save the cookies that you want to be saved but, if they get deleted, they are easily replaced.
