do not understand speccy
I just ran speccy and to be honest I am not sure what I am looking at
Not sure this qualifies as a bug. Also not sure I understand the question. Speccy shows what hardware devices are in your PC. Maybe if you explained what you thought it'd give you, me or someone else can explain better.
I was on a technical support forum and they told me to run it. I did and I cant tell what it is and now im not getting any answers from those that told me to run it
Note: Each time you start Speccy, it will generate a new randomized URL. This is useful if you want to track your computer's information over time.
To publish a Speccy profile to the Web:
In Speccy, click File, and then click Publish Snapshot.
In the Publish Snapshot dialog box, click Yes to enable Speccy to proceed.
Speccy publishes the profile and displays a second Publish Snapshot. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.
Note: The published profile will use the same language and temperature settings (Imperial or Metric) as your Speccy installation.
You will get an address which will look something like this (not this one obviously :) )
https://speccy.piriform.com/results/nGmV1yekiTFbWJJ1oggVwcV
You then post that on the forum. They will click on it and be able to see what hardware etc you machine has (no personally identifying info will be shown from the link)
