I just installed and ran CCleaner and I keep getting this message pop up all the time (I was getting it before I installed CCleaner and thought by running this program it would take care of it): ARCCON_DIRGetADSystemFolder could not be located in the dynamic link library ArcCon.dll. Please help me get rid of this message - its soooo annoying - especially when I don't know what it means or where it came from all of a sudden! It seems to pop up every couple of minutes. Thanks so much for your help (and hopefully my sanity)!!
It seems like it's related to Arcsoft software that you have installed.
Perhaps if you still have the cd for it, you could try uninstalling the software via add/remove programs and then reinstalling it.
Hello lamonica13,
Welcome to the forums !!!
Apparently you have no idea what the message is relating to.
This link sounds very similar.
http://www.bleepingcomputer.com/forums/topic140681.html
Hope it helps.
Good luck, davey
P.S. Just noticed Hazel's reply. Time flies when you are having fun.
