I used defraggler to schedule several quick defrags on different drive, days and times. Next I checked the task scheduler and all the conditions seemed to be in place. The action generated by defragger appear to have the right "stuff". It referenced df64.exe, the drive letter, and so forth.
So I used the task scheduler option to run it. According to the history the task was over and successfully done in ONE second.
No errors, everything stops and starts like it is suppose to, it reports everything was successful; which is true if you consider doing absolutely nothing a success.
Yes, defragger was off and went I went into that the quick defrag worked just fine, thought it took a bit longer than one second.
