DESKTOP CCLEANER PREMIUM ICON MISSING
For some reason my desktop icon for my CCleaner Premium program has disappeared and I cannot find a way to replace it.
Please advise?
* You can copy the Start Menu shortcut to the desktop to restore it.
* Or right click an empty area on the desktop and select New>Shortcut, then browse to the install path where CCleaner is and select CCleaner.exe.
* Or if all else fails you can reinstall CCleaner over your already installed version, and during setup make sure you have the box enabled/ticked that will create a desktop shortcut.
