I got the new ccleaner pro and started the app, it deleted all my chrome and edge, only residue to icons were remaining, it was so frustrating what a nonsense app i downloaded. I tried installing chrome it does not allow with an error no update available, edge is not opening. I uninstalled this software, i will have to install the OS again.
In another post you said that it was your browser extensions that had stopped working, and yet here you say that Chrome and Edge browsers have stopped working altogether.
It’s unlikely that CCleaner would stop one browser from working at all, let alone 2-browsers.
And disabling or removing Edge is next to impossible - it’s built in as a part of the Windows OS.
If your browsers have stopped launching from their icons then it sounds to me that you may have just somehow broken the shortcut to your icons - what does Windows say when you click on the icons?
Try opening the start menu and typing Edge - can you open it from there?
This is Win11 but Win10 is similar:
If you can’t see or open Edge from there then you may have a bigger issue, if you are capable of running system troubleshooting commands then I would run DISM and SFC to check your Windows System Files.
(If something is corrupted that badly that Edge won’t launch then you may well be looking at a reinstall of Windows).
