I don't know if it's normal but I don't have days to defrag a unit (30GB!!!).
I let it go for a while and then I'm gonna stop it.
This program doesn't cause me a good impression...
Hi Rog,
Yes,go ahead and "Stop" it.
Try defragging all the smaller files first.Do not try defragging everything at once.There are some known bugs.
Do not defrag any System Volume files.It will defragment a lot quicker this way.
Do it this way.Start Defraggler then click on Analyze.When that completes Click the box on the left next to where it says "filename".
This will check all the files. Now click on Size this will put all small files first in the list.Click on "Size" again this will put all the large files at the beginning of the list.Untick as many large files as possible.Untick all System Volume files.
Of course you don't have anything else running like games or music to slow it down.
I think "defrag drive" function is totally messed up in the latest version. "defrag drive" only increases fragments more and more after hours. Don't use it.
Use defrag files (push "analyze" button and then "defrag" button) and then perhaps "advanced" -> "defrag freespace" function.
I would like to say two things. One I have a run the latest Defraggler on an 83.5 GB partition, half full, and it has at most taken probably around an hour to perform the defrag. Two it increases the fragments because it is quickly moving the files to outside of the disk so that it can then replace them contiguously, combining the defrag files and defrag freespace functions. I do not know why it would take long on other computers, as mine is about four, five years old and everything in it is at least one generation old and mediocre at that. As davey pointed out, maybe you have other things running that are slowing it down. Perhaps you should try turning off your virus scan, as some of them will try to scan every file that is read and written, which is exactly what Defraggler does.
Good luck,
davey
I stopped the program and I used the windows tool. It worked perfectly. Then I did what you say for the other volumes (including D in the main hd) and it worked!
The partition has not volume files or programs, just data. I don't know what went wrong perhaps the program have some bugs doing entire volume defragmentation.
Anyway I never use the hd when I running a defragmentetion tool.
