Maybe I should test this out before posting, but ...
I really like defraggler, but the schedule option calls the silent DF.exe instead of Defraggler.exe.
This creates a few problems:
* No notification that a defrag is starting - other than HD noise and slow computer response.
* No notification that a defrag finished, so I might shut down the PC while the defrag is still in process.
First Question - Is it possible to add a scheduled task to run defraggler.exe instead of df.exe? (Do the same command line options work?)
Second Question - I understand scheduled tasks enough to understand they will run at next boot if the PC is off at the scheduled time. I understand DF can only process one drive at a time. If I schedule it to Defrag Drive C at 8:00 and Drive D at 8:01, will it wait till C is finished and do D, or do I need to account for the time it will take to run.
Thanks in advance!!!!
BTW - changing the scheduled task from df.exe to defraggler.exe does NOT work!!!
I concur and I would like to add (rather than create yet another topic) the following:
- a way to schedule the scans from install (slient install)
- a way to control what is installed and where (silent install)
I am creating an nLite installer disk to help make installing Operating Systems with needed applications much easier.
Hope there is a way of doing all this, or that you will consider this as an Enhancement Request.
A animated defraggler icon in next to the system time would be a good way to show the user that defraggler is running...
Actually, I no longer use Defraggler - it was taking forever on one of my drives, so I went back to the product I was previously using.
I would like to hope development will continue on it, however.
