Defraggler seems to have increased fragmentation ?
Hi, used defraggler 2.10.424. Was originally fragmented 5% and now it is fragmented 12,8%.
Win xp sp3 updated, turned off everything that I could/shoud in task manager and msconfig,set 'no paging file', disabled internet. Auto-scan on reboot (does not show UI when defragging??)
40 gig 5400 rpm hitachi pata ide
capacity 37,3, free space 24,4 NTFS
Drive info: Health=good
configuration settings (Defraggler.ini):
[software\Piriform\Defraggler]
MainWindowTopSplitterProportionalPos=1379
MainWindowBottomSplitterProportionalPos=2050
UpdateCheck=0
NewVersion=
UpdateKey=19700101
UpdateFrequency=10
UpdateBackground=0
InstallPath=C:\Program Files\Defraggler
Executable=Defraggler.exe
CleanupDriveBeforeDefrag=0
ShowCleanupPrompt=1
Priority=32801
CacheFileCollectionAfterDriveSwitch=0
DisableShellExtension=0
ReplaceWindowsDefrag=0
StopVssWhenDefrag=1
PreviousDefragPath=
ShowFragmentedFolderEntries=1
MoveLargeFilesToEndOfDrive=0
MinLargeFileSize=0
MoveOnlySelectedLargeFileCategories=0
LargeFilesCategories=Movie files;0|Disk images;0|Archives;0
LargeFilesExtensions=*.avi|*.mkv|*.mpg|*.mov|*.mp4|*.mpeg|*.wmv<*.bin|*.iso|*.mdf<*.arj|*.tar|*.rar|*.zip|*.cab
DefragFreeSpaceMoveLargeFiles=0
NativeMode=1
EnableNativeDefrag=1
QDUseCustomParameters=0
QDMinFragmentSize=1;50
QDMaxFragmentCount=0;2
QDMinFileSize=0;0
QDMaxFileSize=0;100
FFPolicy0=WC:1|*System Volume Information*|
FFPolicy1=WC:1|*hiberfil.sys|
Excluded1=FILE|C:\Documents and Settings\Administrator\My Documents\Downloads\Backup 1 all installed before defrag.bkf
Excluded2=PATH|R|C:\System Volume Information|*
Language=1033
CelsiusTemperatureFormat=0
DriveMapColors=0:8046565;1:12681634;2:65535;3:49152;4:255;5:16711680;6:6517215;7:8491005;8:12028509;9:14002309;10:16777215;11:4605510;12:16777215;
ColorsMode=1
DriveMapSettingsMode=0
DriveMapMinBlockWidth=10
DriveMapMinBlockHeight=14
DriveMapMode=1
DriveMapDrawingMode=1
DefragContextString=&Defragment
AnalyzeContextString=&Check Fragmentation
window_left=143
window_top=110
window_width=738
window_height=548
window_max=3
window_flags=2
filelist_columns=2;0;(0;180);(1;28);(2;70);(3;70);(4;212);
CrashDumpEnabledBackup=2
LogEventBackup=1
1 Read Error Rate 0 100 100 62 0x000000000000
2 Throughput Performance 4,561 105 105 40 0x0000000011D1
3 Spin-Up Time 1 ms 201 201 33 0x000000000001
4 Start/Stop Count 3,511 98 98 0 0x000000000DB7
5 Reallocated Sectors Count 0 100 100 5 0x000000000000
7 Seek Error Rate 0 100 100 67 0x000000000000
8 Seek Time Performance 34 132 132 40 0x000000000022
9 Power-On Hours (POH) 286d 5h 85 85 0 0x000000001AD5
10 Spin Retry Count 0 100 100 60 0x000000000000
12 Power Cycle Count 1,766 99 99 0 0x0000000006E6
191 G-sense Error Rate 458,769 94 94 0 0x000000070011
192 Power-off Retract Count 144 100 100 0 0x000000000090
193 Load Cycle Count 116,928 89 89 0 0x00000001C8C0
194 Temperature 37 ?C 148 148 0 0x000000060025
196 Reallocation Event Count 30 100 100 0 0x00000000001E
197 Current Pending Sector Count 0 100 100 0 0x000000000000
198 Uncorrectable Sector Count 0 100 100 0 0x000000000000
199 UltraDMA CRC Error Count 0 200 200 0 0x000000000000
I cant find a log file (is there one? is it needed?)
So if anyone KNOWS what the problem here is then plese tell me. Ccleaner is such a good program but this does not seem right.
PS. A comment like 'you did not need to use it anyway since you were only 5% fragmented" is not helpful.
I used it to try out the program. Before (possibly) buying the pro.
ALSO: (to piriform) im sorry to publicly report this on a forum. Attempted to get support from piriform but cant get without a purchase.
thanks
Go into Defraggler options & exclude Hibernation & Restore points from defragging. Also, checkmark to disable VSS.
