Defraggler Schedule Issue
Ive set up defraggler to do a scheduled defrag of all my drives, and I know its working because I can see df64.exe in task manager. But for some reason I can't open the program to see how much its done, its only viewable in task manager.
Is there a way I can open the program to see how much its done, rather than just assuming its working?
don't run df64.exe if you want a Graphic view of it. df*.exe is command line only. run defraggler64.exe if you are going to want to see the process as it has the GUI.
