Zange0
16 December 2014 04:18
1
See my 4th response for (confusing) resolution.
Running defraggler consumes more space and makes fragmentation worse.
I've followed the advice of:
http://forum.piriform.com/index.php?showtopic=35459 (stop VSS expansion)
http://forum.piriform.com/index.php?showtopic=35458 (exclude restore point and hibernation files)
as well as deleting restore points to see if it would get me the space back (it didn't).
It is getting to a severe and problematic point, and the windows defragmenter is doing nothing to fix is.
I'm on Windows 7 x64 running the most recent version of defraggler.
Images of the problem:
Norrie
16 December 2014 04:50
2
I have the same problem Reported it a few days ago... Seems it added or corrupted some Sys files
See Added Sys Files http://forum.piriform.com/index.php?showtopic=42450
the files seem to grow bigger when I defrag and it is now 43% fragmented and it is in those files only.
I will be watching here to see what happens
Norrie
17 December 2014 18:02
3
Zange0
18 December 2014 00:01
4
I've already tried clearing the restore points, it didn't really help, and that wouldn't fix the fragmentation from what I understand.
Norrie
18 December 2014 04:04
5
It did seem to fix mine, at least for now. But I had to clear all and make a new restore point.
I was at 65GB but it dropped to 38GB after I did this.
I do think it is something with defraggler because if I used system tool defrag it did not add anything.
I just hope they take a look at it and figure out what is causing it.
BTW I have used defraggler now for at least 5 years and until now really liked it.
Norrie
18 December 2014 17:07
6
Maybe this will help.
I wrote to Piriform and received this answer:
"It's likely that the increase of used space is attributed to Windows creation of Volume Shadow Copies during the defragmentation process, so I would recommend that you prevent the creation of these unwanted files since they'll use this disc space.
To configure Defraggler to prevent the creation of the Volume Shadow Copies when defragging:
Open Defraggler
Click Settings > Options…
Click on the Advanced tab
Check “Stop VSS when defragmenting NTFS volume” > click OK.
You can find instructions on how to regain the lost disc space here:
http://support.piriform.com/entries/21202696-Claiming-back-your-Free-Space-caused-by-VSS
If you're having any trouble with this, or if you need anything, please feel free to email me back.
Regards Megan"
Norrie
Nergal
18 December 2014 18:32
7
Norrie, in the first post Zange says he already tried stopping vss
Zange0
19 December 2014 09:42
8
I got a response from support saying that I should delete my restore points, which still hasn't fixed anything.
Does anyone have any suggestions other than 3 things that keep coming up?
Zange0
31 December 2014 07:29
9
So, I don't know what happened, but after restarting my computer earlier this evening, the fragmentation suddenly dropped to 1% and I gained over 300GB of space back.
If there is anything anyone can think of for me to provide to help people in the future I will, but right now I'm just happy, if not a little confused.
Zange0 a reboot cures 90% of computer issues.
Glad you are all set up again and ready to face another year
Zange0
31 December 2014 23:08
11
The odd thing was is that I'd rebooted several times since then, as long as I've got my space back though, I'm content.
