Defraggler Issues
I just got the latest version (1.1.44) and although it works a whole lot faster on the analysis side, its not reporting correctly. No matter which of my (3) hd I analyse, it reports files of only 1 size (268,768KB) are found, they are all called $MFT and they have various fragments ranging from 3 to hundreds. Is there a problem I dont know of??
Thanks iceberg
*edit* After trying to dr-frag some of the files, de-fraggler dosent do anything it just stays at 0% :(
I wanted more of Defraggler too...
In first place the program need go out of beta, it is not hard!!!
After a comp re-start, it now analyses one of my external hd properly and will de-frag it (sort of). Sadly still the same with my other 2 hd tho :(
Can you post the debug log here please. Instructions can be found at
http://forum.piriform.com/index.php?showtopic=12840
MrRon
ok bro it is hard, u cant rush a product. u just go...ok its been in beta 4 a couple weeks its good now. they need to work out bugs then they will release the final version.
Hello,
I tried out Defraggler also and I am sorry to say, even though it has a interesting concept, the program, version 1.1.44, has some problems on my XP SP2 system, 80 GB HD. After analyzing, it found and listed 3.2 GB of fragmented files, ran defrag and the program self aborted at 49% defragging files, analyzed and ran the defrag again, the program got to and "hung" at 18% defragging the free space, for over an hour, before I aborted the procedure. Once again, I analyzed, the program showed 0 fragmented files. Just for fun I ran the Windows Defragmenter, immediately after, it showed a few fragmented files but hardly enough to bother mentioning.
I did find the analysis was quick, and defragging individual files and smaller groups of selected files, Defraggler, seemed to work just fine.
Anyway, I see that there is a debug setting for the program. In a week or so I will test it again and send a report if needed.
Thank you for hearing me out,
Merry Christmas,
Wink
MrRon
Ok one de-frag log - (Hope its not too big!)
[2007-12-26] [10:48:45.135] 00b50 0 ATLX::CAtlXTraceLogger::LogApplicationInfo#461 C:\Program Files\Defraggler\defraggler.exe
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogApplicationInfo#490 FileVersion: 1.1.0.44
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogApplicationInfo#491 ProductVersion: 1.1.0.44
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogApplicationInfo#492 Flags: 0x00000000, OS: 0x00000004, Type: 0x00000002, Subtype: 0x00000000
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#508 Computer name: Homer
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#515 User name: Paul
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#523 OEM ID: 0
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#524 Number of processors: 1
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#525 Page size: 4096
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#526 Processor type: 586
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#527 Minimum application address: 10000
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#528 Maximum application address: 7ffeffff
[2007-12-26] [10:48:45.151] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#529 Active processor mask: 1
[2007-12-26] [10:48:45.167] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#532 Clean boot: 0
[2007-12-26] [10:48:45.167] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#533 Monitors: 1, Display: 1152x864, Virtual: 0x0 1152x864
[2007-12-26] [10:48:45.167] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#543 Major: 0x00000005, Minor: 0x00000001, Build: 2600, PlatformId: 0x00000002
[2007-12-26] [10:48:45.167] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#544 SPMajor: 0x0002, SPMinor: 0x0000, CSDVersion: "Service Pack 2"
[2007-12-26] [10:48:45.167] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#545 SuiteMask: 0x00000300, ProductType: 0x00000001
[2007-12-26] [10:48:45.167] 00b50 0 ATLX::CAtlXTraceLogger::LogSystemInfo#557 Memory: Load: 49, Physical: 805117952/1610014720, PageFile: 2403229696/3133566976, Virtual: 2118901760/2147352576, Extended 0
[2007-12-26] [10:48:45.167] 00b50 0 ParseCmdLine#20 /debug
[2007-12-26] [10:48:45.292] 00b50 0 CMainFrame::OnCreate#92 Entering CMainFrame::OnCreate
[2007-12-26] [10:48:45.292] 00b50 0 CMainFrame::OnCreate#128 Creating driveListForm_.
[2007-12-26] [10:48:45.307] 00b50 0 CMainFrame::OnCreate#130 Creating driveMapForm_.
[2007-12-26] [10:48:45.307] 00b50 0 CMainFrame::OnCreate#132 Creating fileListForm_.
[2007-12-26] [10:48:45.338] 00b50 0 CMainFrame::OnCreate#135 Updating layout.
[2007-12-26] [10:48:45.338] 00b50 0 CMainFrame::OnCreate#163 Registering object for message filtering.
[2007-12-26] [10:48:45.338] 00b50 0 CMainFrame::OnCreate#172 Initializing VolumeManager.
[2007-12-26] [10:48:45.385] 00b50 0 CVolumeManager::Initialize#14 Entering CVolumeManager::Initialize
[2007-12-26] [10:48:45.401] 00b50 0 CVolumeManager::Initialize#24 Enabling SE_BACKUP_NAME privilege succeeded.
[2007-12-26] [10:48:45.401] 00b50 0 CVolumeManager::Initialize#30 Enabling SE_RESTORE_NAME privilege succeeded.
[2007-12-26] [10:48:45.401] 00b50 0 CVolumeManager::Initialize#49 Leaving CVolumeManager::Initialize
[2007-12-26] [10:48:45.401] 00b50 0 CMainFrame::OnCreate#177 Initializing VolumeNavigator.
[2007-12-26] [10:48:45.401] 00950 0 CVolumeManager::RebuildVolumesMap#127 Logical drives mask: 0x00001ffd, arrival mask: 0xffffffff, removal mask: 0x00000000.
[2007-12-26] [10:48:45.401] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume A:.
[2007-12-26] [10:48:45.401] 00b50 0 CDriveMap::CDriveMap#14 Constructor.
[2007-12-26] [10:48:45.401] 00950 0 CVolumeManager::UpdateVolume#318 Volume: A:, size: 0, free: 0, fs: Unknown, name: "".
[2007-12-26] [10:48:45.401] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi A:.
[2007-12-26] [10:48:45.401] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume C:.
[2007-12-26] [10:48:45.401] 00b50 0 CVolumeNavigator::CVolumeNavigator#9 Constructor.
[2007-12-26] [10:48:45.401] 00b50 0 CVolumeNavigator::Initialize#20 Initialization started...
[2007-12-26] [10:48:45.401] 00b50 0 CVolumeNavigator::ConnectToVolumeSignals#109 Connecting to volume A: signals.
[2007-12-26] [10:48:45.401] 00b50 0 CVolumeNavigator::Initialize#68 Initialization finished.
[2007-12-26] [10:48:45.635] 00950 0 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#75 Registered notification for "C:\", handle: 0x000001b0
[2007-12-26] [10:48:45.760] 00950 0 CVolumeManager::UpdateVolume#318 Volume: C:, size: 160031015424, free: 31239479296, fs: NTFS, name: "BOOT".
[2007-12-26] [10:48:45.760] 00b50 0 CVolumeNavigator::SelectVolume#262 New volume selected: A:.
[2007-12-26] [10:48:45.760] 00b50 0 CVolumeNavigator::ConnectToVolumeSignals#109 Connecting to volume C: signals.
[2007-12-26] [10:48:45.776] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi C:.
[2007-12-26] [10:48:45.776] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume D:.
[2007-12-26] [10:48:45.776] 00950 0 CVolumeManager::GetBasicVolumeInfo#244 Unsupported drive type 5 for volume D:
[2007-12-26] [10:48:45.776] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi D:.
[2007-12-26] [10:48:45.776] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume E:.
[2007-12-26] [10:48:45.776] 00950 0 CVolumeManager::GetBasicVolumeInfo#244 Unsupported drive type 5 for volume E:
[2007-12-26] [10:48:45.776] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi E:.
[2007-12-26] [10:48:45.776] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume F:.
[2007-12-26] [10:48:45.792] 00b50 0 CFilesListViewImpl::DoSort#146 Sorting 0 elements took 0.0000 seconds
[2007-12-26] [10:48:45.792] 00b50 0 CMainFrame::OnCreate#241 Leaving CMainFrame::OnCreate
[2007-12-26] [10:48:46.104] 00950 0 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#71 Registering notification for "F:\" failed with error code: 21
[2007-12-26] [10:48:46.354] 00950 0 CVolumeManager::UpdateVolume#318 Volume: F:, size: 0, free: 0, fs: Unknown, name: "".
[2007-12-26] [10:48:46.354] 00b50 0 CVolumeNavigator::ConnectToVolumeSignals#109 Connecting to volume F: signals.
[2007-12-26] [10:48:46.385] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi F:.
[2007-12-26] [10:48:46.385] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume G:.
[2007-12-26] [10:48:46.713] 00950 0 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#71 Registering notification for "G:\" failed with error code: 21
[2007-12-26] [10:48:46.948] 00950 0 CVolumeManager::UpdateVolume#318 Volume: G:, size: 0, free: 0, fs: Unknown, name: "".
[2007-12-26] [10:48:46.948] 00b50 0 CVolumeNavigator::ConnectToVolumeSignals#109 Connecting to volume G: signals.
[2007-12-26] [10:48:46.963] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi G:.
[2007-12-26] [10:48:46.963] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume H:.
[2007-12-26] [10:48:47.260] 00950 0 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#71 Registering notification for "H:\" failed with error code: 21
[2007-12-26] [10:48:47.542] 00950 0 CVolumeManager::UpdateVolume#318 Volume: H:, size: 0, free: 0, fs: Unknown, name: "".
[2007-12-26] [10:48:47.542] 00b50 0 CVolumeNavigator::ConnectToVolumeSignals#109 Connecting to volume H: signals.
[2007-12-26] [10:48:47.542] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi H:.
[2007-12-26] [10:48:47.542] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume I:.
[2007-12-26] [10:48:47.838] 00950 0 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#71 Registering notification for "I:\" failed with error code: 21
[2007-12-26] [10:48:48.073] 00950 0 CVolumeManager::UpdateVolume#318 Volume: I:, size: 0, free: 0, fs: Unknown, name: "".
[2007-12-26] [10:48:48.073] 00b50 0 CVolumeNavigator::ConnectToVolumeSignals#109 Connecting to volume I: signals.
[2007-12-26] [10:48:48.088] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi I:.
[2007-12-26] [10:48:48.088] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume J:.
[2007-12-26] [10:48:48.213] 00950 0 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#75 Registered notification for "J:\", handle: 0x000001b8
[2007-12-26] [10:48:48.323] 00950 0 CVolumeManager::UpdateVolume#318 Volume: J:, size: 250048479744, free: 32046403584, fs: NTFS, name: "EXTERNAL HD".
[2007-12-26] [10:48:48.323] 00b50 0 CVolumeNavigator::ConnectToVolumeSignals#109 Connecting to volume J: signals.
[2007-12-26] [10:48:48.323] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi J:.
[2007-12-26] [10:48:48.323] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume K:.
[2007-12-26] [10:48:48.385] 00950 0 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#75 Registered notification for "K:\", handle: 0x000001bc
[2007-12-26] [10:48:48.401] 00950 0 CVolumeManager::UpdateVolume#318 Volume: K:, size: 250994386944, free: 43745083392, fs: NTFS, name: "BackUps".
[2007-12-26] [10:48:48.401] 00b50 0 CVolumeNavigator::ConnectToVolumeSignals#109 Connecting to volume K: signals.
[2007-12-26] [10:48:48.432] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi K:.
[2007-12-26] [10:48:48.432] 00950 0 CVolumeManager::UpdateVolume#289 Start update for volume L:.
[2007-12-26] [10:48:48.432] 00950 0 CVolumeManager::GetBasicVolumeInfo#244 Unsupported drive type 5 for volume L:
[2007-12-26] [10:48:48.432] 00950 0 CVolumeManager::UpdateVolume#339 Finish update for bvi L:.
[2007-12-26] [10:48:48.432] 00950 0 CVolumeManager::ChangeNotificationOwner::ChangeNotificationOwner#75 Registered notification
