Defraggler help!
hello everybody im using defraggler right now and i just pressed analyse and then defrag thats it but i have got 122gb music (mp3) does the defraggler throw that out too.kind regards casi
I'm not sure if I understand the question. :unsure:
If you hit defrag then it will defrag all files on your drive except for locked or protected files.
If you're referring to exclusion of file types then yes it's possible to define an ignore list.
Richard S.
