Defraggler freezes after analysis
Hello!
I'm using Defraggler for quite some time now--and first of all, I have to say that it is a very nice program--, but since a few versions the following problem occurs on my notebook: when I try to analyze my second partition D (logical, NTFS) on my notebook (Windows Vista), the program always freezes after the analysis is complete! I started it in debug mode and the last log entry says:
00218 1 CVolumeOperationScheduler::ExecuteQueuedMethods#232 ---------------- Long task finished (time: 22.689s, return code: 0x00000000) ----------------
However, the analysis works on my primary partition C and it also works on my PC (Windows XP) which has the same setup (2 partitions on the same physical drive). So, what's up with that? Why does it freeze? Unfortunately, I don't know with which version that started, but I just updated to version 1.14.159 and the problem is still there. Any ideas? :unsure:
One other thing: if the program would freeze/crash while defragmenting, is there a risk of data loss? Can my files become corrupted or something?
This is strange. I would reinstall Defraggler - v1.14.159. If this continues you should ask the guys in Spyware Hell here on Piriform Forums if something else is involved. It's not necessarily Defraggler that's causing this.
