Hello, I am a frequent user of yours products with full satisfaction but this time it goes over a serious issue with "defraggler".
I had 21% fragmentation on my C:\ HDD (1To from which 200Go still available) so I made the fast option that produced a little result only.
I decided to use then the second option "defrag", but unfortunately after a while I got a screen "error" and everything stopped.
I checked the properties of my C:\ HDD and it was almost full with only 20 Gb free !!!
Please help, what can I do ??
Thanks in advance to all those who will be so kind to help me,
Pol
go to Settings, Options, Advanced tab, check <strong>Stop VSS</strong> is not ticked.
tick <strong>Use Custom fragmentation settings </strong>and click the Define button, in there, tick both options.
as to now only having 20GB free, try a reboot of the PC to see if that helps.
failing that, try the following.
go to Control Panel (change<strong> View by </strong>to icons), System, System Protection, Configure button, set Max Usage to 1% and hit Delete, then OK.
now you're back on the previous windows, click Create to make a new Restore Point (since we just blew all the others away)
- Run Antibody's WizTree. It will tell you what the size all the folders on your HD have. Including that folder called "System Volume Information" which contains the System Restore Points.
I am not sure I understand completely the manipulations described...
If I understand well, the VSS function being disabled should prevent to keep a copy of all the files being deffraged ?
Is there a way to identify the recuperation files created by defraggler or are they just an additional restoration point in windows ?
To recover space could I simply delete all files of the existing "restore points" of windows and then recreate manually a new "restore point" via windows ?
Thank you for continuing guiding me to the right solution...
- Sometimes deleting all System Restore Points (SRP) won't help. Then one has to switch off the "System Restore point" feature in Windows and switch it on again. Only that way one can free up all disk space. Although I wouldn't recommend to do that in the first instance.
- Yes, the combination of DEFRAGGLER and VSS (used for making SRPs) can lead to some unpredictable results. As you have seen. DEFRAGGLER seems to - somehow - trigger the VSS subsystem in Windows. It also has been reported that DEFRAGGLER deletes SRPs.
- Although I also know that when one's HD gets filled too much, Windows will automatically delete one or more SRPs.
