After the latest update, the colours are not showing, all I get are shades of grey.
I have looked at the Setings and see no way of fixing this. All previous versions were OK. My version is v2.10.424. The Drive Map settings are on Modern View and the Colours are all greyed out, there is no facility to change them.
I cannot reproduce/confirm this. And it seems a very weird issue. Are you sure it's only Defraggler?
Yes, it is just my Defraggler. The files are shown in various grey`s on opening and when it is Defragging, yellow shows and brown for the Pagefiles, with a few purple and red`s, but the rest are shades of a pale blue/green colour. It just looks different from my previous versions.
I suppose it is OK, but I am sure there were colours shown before on opening instead of grey`s. Perhaps I am mistaken.
It works OK, so maybe I am wasting everybodies time and if this is the case, I sincerely apologise.
For the moment, it is probably best to see how it goes.
That is the correct display for Modern View. Switch to Original View or Custom View and see what happens.
Switched to Custom View as suggested by yourself and Power. On opening, the small squares have changed to bars and still there is no colour at Opening or Analysing. The only colours that appear are on Defragging. All other views are in grey, opening and analysing. Here are the screen shots :-
