Define 'Health' Main/Top Categories
Under the 'Health' tab, there are Attribute Name and 4 others: Real Value, Current, Worst, and Threshold. What do these terms mean? For example, it seems that Real Value is (should be) the same as Current --but the numbers are not the same. Worst (I assume) is the worst ever recorded for this hard drive --and is not the worst ever recorded in the whole world. Threshold is (I assume) the tipping point --good/acceptable on one side and bad on the other side. A "real world" example is what should be easy to understand but is not: Temperature values are 36, 64, 44, and 95. Other Attribute Names require comprehension of the item -and then- what the numbers mean. Temperature is an attribute easily understood by everyone -but- the numbers shown are... what? Thank you for your time. I'm certain that this could be edited to make it more understandable to everyone (hopefully without having to define each attribute!).
The data provide is the S.M.A.R.T. data
More here
https://en.wikipedia.org/wiki/S.M.A.R.T
