Default settings
I want th epossibility to reset the settings in every tab to the original value?s.
Today i have some problems because i changed to much and i don?t know what are default settings and what did i marked.
Go into CCleaners program folder (C:\Program Files\CCleaner) and delete the 'CCleaner configuration settings' file (this will remove ALL your settings)
