Data Recovery from a Reformatted Sandisk Memory Card
I scanned 591 color slides onto a Sandisk memory card, I then accidentally (stupid really) reformatted the memory card and “deleted” (or so I think) and the memory card now says “folder empty”. I tried using Recuva and selected “All Files” and selected “specific location” and then browse and came to the specific drive which says COACH100 (where the .jpg images would have been (had I not reformatted the memory card) so my question is does anybody know if I can still recover these .jpg color slide images , or are they ruly permanently deleted? If you would be so kind as to inform me that you have answered please send me an e-mail to : [email address removed]or text me at: [phone number removed]. Thank you sincerely, Thomas R
Please don’t publish your personal information in a public forum, it attracts spammers and scammers to both you and this site.
Recovery from flash memory (like your sd card) is harder (slightly impossible) than a hard drive. The way flash memory treats deletions is different.
@thechosen2024
It can be done by Revuva, if you use the right method.
See this for step by step instructions, plus there is a video link where the guy uses Recuva in that way to recover images from a reformatted SD card:
