Data captured---not accurate?
I just installed a new Asus motherboard with CPU Intel-i3-2100. After setting up, I run the Speccy and see if the fan speed setting and CPU / motherboard / SDD temperature are working normally. However, these captured data when comparing with those using the Asus softwares--Senor Recorder that comes with the motherboard, the figures have significant different. Please refer to the snapshot enclosed which explain clearly what are the problems detected.
My questions : which program is working properly or none of them working properly??,
Speccy-V-Asus sensor-2014-06-28.pdf
