D?sinstallation de CCleaner
Bonjour,
J'ai besoin de savoir comment d?sinstaller, d?finitivement et proprement , CCLEANER de mon syst?me Windows XP SP3.
En effet, il n'apparait pas dans la liste : Panneau de Configuration / ajout-suppression de programmes, ni dans les options de Ccleaner ??
REMERCIEMENTS pour toute aide.
Papy95
This is a english spekaing forum, can you repost please, there are a few members who can speak french.
Hello,
I need to know how to uninstall, finally and properly, CCleaner on my Windows XP SP3.
Indeed, it does not appear in the list: Control Panel / Add-Remove Programs or in options Ccleaner?
THANKS for any help.
Papy95
I'm not sure you will understand my english reply.
Download and install Revo Uninstaller
Select CCleaner and it should uninstall it
Bonjour,
Merci ? tous pour votre aide.
CCleaner a ?t? d?sinstall? correctement.
Remerciements
De rien :)
