Customizing Analyses - CCleaner for Android (1.04.24)
I have managed to inadvertently remove SMS messages from the "automatic cleaning" process. Is there anyway to add it back? I have a Galaxy SII (Jelly Bean 4.1.2)
Thanks for your help.
Welcome to the forum bdlacy,
I don't know what you mean by "automatic cleaning", but if you just need to add SMS messages to the analyse try this...
Settings > Customize Analyses > tap on SMS and you should see a check mark appear indicating that it will be included in analyze. After you analyze, make sure the box next to SMS in the results window is checked so that it will be included in cleaning.
You can also customize what is to be deleted in the received and sent results. Tap the marker on the right, then tap on your desired setting.
Edit: If you're referring to the "Quick Clean" widget as "automatic cleaning", SMS messages is not an option on my phone.
